1 - 18 of 18 Posts
Who’s running a HKS triple plate clutch? I am in the position to obtain one for my car which is a R34 GTR I will be running about 600 BHP and wanted some feedback about this clutch.
Very on-off and forget it in traffic or hill starts!
Lived with mine for a few years as it was already in the car. Running same power as you so needed to be a tripple when you look at the ratings.
I ended up blowing my OS box so took the opertunity while it was out to change to an OS tripple.
So easy to drive now. Wish I had done it years ago.
Advice would be consider what you do with your car. If your big into drag racing then it's ideal for full bore launches. If it's a daily driver avoid it.
I run a HKS tripple in my R32 Drag car which i also use as a daily driver :D its all good to be honest, just a case of getting used to it i suppose. Most of my cars have run an uprated clutch of some sort but i was very suprised at how useable on the road this clutch was even in traffic :D obviously its harder to use but once u know what to expect you just get on and drive. Hope this helps dude:thumbsup:
My experience as well. I've had 3 different triple plate clutches in my R34. First HKS - not happy. Then OSG triple - much better but a little heavier than I thought it should be. Then ATS Triple Carbon - perfect for street.
I've run the HKS triple for several years. (The HKS twin at 600bhp will slip) .It's true the triple is very much on/off when set up with the sprung cylinder rod and can be a right pain at traffic lights neading either a full on launch or a tickover pull away to avoid bogging. I did put up with it though because it refused to wear out and took any amount of abuse on the strip and to a certain extent I did eventually get used to it on the road.
However when we last had the gearbox out we renewed the plates, changed to a solid adjustable rod coming out of the slave cylinder and made some careful adjustments to pedal and thrust bearing clearances. This made a huge difference It is now a completely transformed clutch and much less on/off and seriously not that different in operation to a normal clutch.
Mine is the unsprung hub, which I think yours is, which is harder on the gearbox, I'd like to try a sprung hub sometime. Oh and they are rattly and noisy in case you didn't know at tickover in neutral what with the gearbox rattle as well they sound like a bag of spanners.
don't go twin plate !! Nitemare on - off, you won't like traffic and I was told that a triple would have been better
A friend of mine had an HKS twin in his 34 GTR and it was almost as nasty as the quad in his race car!
However - I have an OS twin in my car and its perfectly driveable and doesnt slip at 605 bhp, although admittedley I dont make a habbit of drag launches.
I think the driveability thing has as much to do with the diameter of the clutch and if the plates are sprung or not.
ive had hks triple in mine for the last four years and you do get used to it to an extent,but as has been said very on/off and really spoils the expereince of driving around town.im having a nismo super coppermix twin fitted on friday so should be a happy chappy,but its probably close to its limit at the power your running.
Discussion Starter #11
Thanks for the replies guys i know the OS Giken and Carbonetics clutch’s seem to be the best all round clutches. I am just going through a full engine rebuild at the moment and can get this clutch at a reasonable price so i am fitting the triple plate HKS for the mean while this will have to do and later change it to a Carbonetics twin plate. I will just have to get used to the on and off clutch unless I can make the same adjustment as blue34 did so it’s easier to use on the road. My car is a road car which is used occasionally so it’s not too much of a problem.
I have a twin plate hks in my 34 and its grand to use, had a triple in my supra before and i hated it in traffic and on hills lol
Ask Sparks about his car, it has the HKS tripple and personally I found it great, so easy to drive, definatly not on/off at all, maybe the extra torque of the RB30 helped but I can't see it being that much different on a 26.
Rob
Discussion Starter #15
Shane I hope the skyline triple plates are different to the Supra and Im guessing it depends how the clutch is set up also?
thanks for your input Rob I have just read sparks build dairy what a car you produced :thumbsup: :bowdown1: great piece of kit. I have sent sparks a PM for his feedback on the clutch.
Nismo twin plates are very good better than standard, but im unsure if it can take that power.
I've got a Nismo twin plate and it's fine, never had an issue and it's just a bit heavier than stock.
Drove a Supra with a HKS tripple and it was literally a switch. Wouldn't want one as a daily driver.
Discussion Starter #17
Sparks has given it the thumbs up and said its not to harsh and it does give you a little warning before biting point. just waiting for my clutch to turn up now. :confused:
thanks for the input everyone will update everyone with my view on it once iv run my car in and tested it properly.
Discussion Starter #18
Just a little update on the clutch, it was fitted and it was a total DOG to drive even after adjusting the pedal, my mechanic suggested shorting the clutch slave cylinder rod so i looked into it and realised that HKS done a rod for this clutch (which i didn’t get with the kit?) after ordering and fitting it, its a lot better now its defiantly a on/off clutch but isn’t as bad with the new springy HKS rod. The spring rod made a hell of a difference.
1 - 18 of 18 Posts
