Hello gang,
I have come up with a cunning plan..
Could you mount two R33 GTR intercoolers back to back and have one fed from each turbo. This would net an increase in flow capacity of more than some of the biggest ic's as you are running 2 60mm thick cores instead of one 110mm core (Nismo racing item)
1. Does anyone think it is worth persuing. ?
2. Will 140mm of intercoolers fit in the gap ?
I would propose that you ran the front turbo to the back intercooler and then the back to the front as I reckon the back turbo probably runs hotter than the front. used in conjunction with a water spray to even the heat up a bit..
Whaddya reckon ?
Steve
Whaddya reckon ?
Steve
