Hi all, just a nice quicki question
Just finished my rebuild of engine, started and runs all ok...
still has the usual idle high (1400rpm) that shes had since day 1 after a lotta different stuff done to her..
anyhow... whilst checking everything on datascan, noticed that the lambda isnt switching at all and just stuck on lean, and the A/F is stuck at 100...
I know when i last checked, she generally sat at lean at idle on the gauge and int switched to rich, and obv when u hold rev's up nicely switches rich/lean, but now she is just sat at 100% lean... if i unplug the sensor and restart. it sticks at 0% rich
the engine is running too well to have a 100% lean scenario so can assume for testing purposes that a lambda has failed, but my Q is... which lambda does the datascan use or which 1 am i likely to be monitoring on the datalogger ? as there is only 1 displayed within the dataviewer and two on the car obv...
any suggestions welcome
oh, and its a 91 gtr, cheers
