1 - 7 of 7 Posts
I am a little bit confused on which injectors that fit the oem fuel rail without any mod. iam aiming for around 700-800 inj. so it safely can support 600 hp.
Thanx in advance
Thanx which manufactor do you use ?
Luffy said:
at the moment i have 600's in a std rail im upgrading to 720's and have been told they should fit straight in.
700cc injectors in standard fuel rail :)
Doubt very much that they'll ever come out again though :D
Luffy,
Having 600s in your standard fuel rail, did you need to upgrade the fuel pump & change the fuel regulator also????
Gav
it was all done in japan but it is running 2 tomei 260lph fuel pumps and a new fuel pressure regulator.
you dont really need 2 fuel pumps so you would probably get away with the one if you going for max 600hp.
1 - 7 of 7 Posts
