1 - 8 of 8 Posts
When installing larger injectors, say 700's, do I have to change some thing in my ECU? I am running an F-Con at the moment.
Thanks for any help I can get on this,
Robb
F-CON
doe's any body have an instruction manual for a F-Con in english?
Or know where I can get one?
Thanks,
Robb
You'll also have to upgrade the fuel pump and fit a fuel pressure regulator to counteract the pressure spikes that occur when using bigger pumps...
I have all that good stuff + some. Just want to make sure every thing works together as best they can.:D
Any Idea on how I can get my hands on an english version of the f-con manual?
cheers,
Robb
You'll Be lucky !!
Robb,
You need to take your car and F-CON to your local HKS Pro dealer. These guys will have everything you need to re-programme your system.
See the website www.hksusa.com for more details.
Gazmo.
Just doing my bit.
1 - 8 of 8 Posts
