Hi does anyone have a diagram of the collector chamber and all the parts that are bolted to it underneath.
A water pipe at the back of the head has burst and i need to remove the collector to get the pipe out.
Has this happened to anyone before?
Its a pin hole in the hard metal pipe behind the head just above a Y joint in the pipe where it splits into 2 and connects onto ruber pipes. I presume it must be turbulance at the joint that coroded the pipe from the inside out.
