1 - 6 of 6 Posts
Is it possible to take off the inlet manifold without completely taking out all the gubbins bolted on underneath?? i'e can you just release the bolts and let the air chamber and pipes hang down to get at the manifold bolts?
Thank you
Skyline Section Manager
You need to undo the bolts for the gubbins underneath and you can slide the plunum off leaving them in situ.
Nice one..
that's just what I wanted to hear!!
Next job will be a polished inlet manifold then!!
I must warn you, its a hard job removing it. Ideally you need a manual so you know whats bolted on underneath and where all the pipes go.
Good luck and don't forget the plasters.:wavey:
I have the engine manual.. thought a mirror might also be handy!? I make it 7 bolts to take out underneath?!
Lee
From memory, I thonk you're spot on. Stubby spanners are the tools of choice along with a 1/4" socket set.
1 - 6 of 6 Posts
