I’m trying to find out where to connect the input wire for a shift light. I could use the rev counter input but that means taking the console apart. Even then I’m not sure which wire that would be. :confused:
There should be an ignition pick up point to connect a timing light. Anyone know where that is?
Paul.
The ignition pickup point is on the ignition amplifier at the back of the rocker cover nearest the bulkhead. There should be one little wire (white or pink maybe) sticking through the loom that you clip the timing light onto.
It may be tidier picking up the pulse from the ECU loom in the passenger footwell though.
Anyone know which pin it is on ?
