With the cars that have this function, can you change music from the cars screen, or do you have to choose the track from the phone?
Screen, as per every car I've personally had with the feature.
Cheers CT, my 350z had bluetooth streaming, but i had to control the music selection via the actual phone. Knowing this will save me buying cds :)
If you set up play lists, then you can select these through the screen too. Just makes it easier to seperate albums or groups of your favourite tracks
Bluetooth streaming doesn't allow playlist selection. You can play, pause, skip tracks next/previous. Tested this with iPhone4/4s/5
It's only when you connect via the USB connector do you have full control of the phone/iPod.
