i am currently changin my clutch in my r32 gtst and have all bolts out except top of starter and top bolt on bell housin cant get at these two is will i have to remove inlet manifold or engine altogether
As above from cord when fitted my new clutch plates from RB. Use a small 14mm to break the lock of the screw. Also a woman's forearm to get up the gap helps if you want to keep your skin.Put bottom starter motor bolt back in (to hold it in place) then either use a short 14mmm spanner, or a pivot headed 14mm ratchet spanner. It's a peice of cake.
Top bellhousing use an extension like the Partridge says.:wavey:
