I have my engine out right now and I am fixing all the little gremlins.I found a power steering leak at the Hicas Solenoid.I have the shop manual and there is no "tear down" of the solenoid.The leak is on the left side where the shiney tube connects to the solenoid.Is there an "O" ring in there that is shot?If I unscrew it to replace it ,I am assuming all the power steering fluid will leak out and I will have to bleed the whole system....correct?How long does it take to bleed the Hicas system?You can see where the drip is above the napkin.
