Hello,
I'm looking to get these baffles (found that Mine's sells them as well HO company) fitted in my RB26. Are these really worth to install?
Is enough a properly oil catch can added for the 550-600 HP crank power figures trying to keep below 8,500 RPM ?
I have been reading quite a bit about the oil drain mod from the back of the head, as well the oil head restrictor that should be used, etc etc but not much info about the cam cover baffles.
My engine is stock so far, so trying to figure out what parts or easy mods start doing/purchasing for my project.
Any suggestion/opinions!?
Thanks,
These baffles are a good addition to stop oil travelling it's way through the breather hoses. You can find replica mines on ebay which are the exact same thing but cost alot less. I will be using a set of these in my build.
