1 - 10 of 10 Posts
I have owned my latest GTR for nearly 2 months now.
Although I have only really had access to her and the keys for a couple of weeks in total, due to experiencing problems with her since purchase - thanks to the frustrating cowboy type antics of the previous owners.
I was determined to take her down the strip to see how well she performed after having been properly repaired and fully setup by TR Racing.
Here are the videos of my 4 runs down the 1/4 mile drag strip there.
Second and third runs being the best of the four.
Best ET was 12.3644.
Best MPH was 118.70.
YouTube - 1st Run - Santa Pod - Jap Show Finale 2009 - Wide Arch (HKS/OSG/ORC) Nissan Skyline R32 GTR - tame launch without launch control
YouTube - 2nd Run - Santa Pod - Jap Show Finale 2009 - Wide Arch (HKS/OSG/ORC) Nissan Skyline R32 GTR - hard-ish launch with launch control
YouTube - 3rd Run - Santa Pod - Jap Show Finale 2009 - Wide Arch (HKS/OSG/ORC) Nissan Skyline R32 GTR - hard-ish launch with launch control
YouTube - 4th Run - Santa Pod - Jap Show Finale 2009 - Wide Arch (HKS/OSG/ORC) Nissan Skyline R32 GTR - relaxed launch without launch control
What do you guys think?
Even though I am now sadly £4,500 lighter than I expected or wanted to be when I initially purchased the car. I can safely say that since picking her up from TR Racing... TR Racing and the GTR have managed to put a smile back to my face.
I was aiming for runs somewhere in the 11's, but with a bit of practice I should be seeing 11 second runs.
Cheers :thumbsup:
Thanks guys.
Current confirmed mechanical specification (ignoring bodywork) is as follows: -
HKS 2.8 Stroker Engine: -
HKS Forged Pistons,
HKS Forged H-Section Con-rods,
HKS Fully Counterweighted & Knife Edged Crankshaft,
HKS Bolts,
HKS Bearings
OS Giken 1-5 H-Pattern Gearbox
Nismo Quick Shifter Kit
GREX Gearbox/Transfer Box Machined Sandwich Plate
NISMO 2-Way Rear Diff
Garrett 2860RS -5 Turbochargers
Garrett Matched & Uprated Actuators
HKS Turbo Elbows
HKS Stage 2 Camshafts
HKS Vernier Pulleys
HKS Valve Springs & Retainers
Trust Kevlar Timing Belt
HKS Oil Pump
NISMO Water Pump
Trust Fully Baffled Sump Extension
NISMO Engine Mounts
NISMO Gearbox Mounts
NISMO Diff Mounts
HKS 1.2mm Metal Head Gasket
ATI Harmonic Crank Damper
HKS Under-Drive Pulley Set
Electric Fan Conversion
Air Con / ABS Still Present & Active
HKS/Denso 700cc Injectors
HKS Fuel Rail
Earls Braided Fuel Lines
Sard Fuel Pressure Regulator
Bosch 044 In-Tank Twin Fuel Pumps
NGK Spark Plugs - new
FET Ignition Coil Packs
Bee-R Radiator
Trust Intercooler
Trust Oil Cooler
GREX Engine Oil Filter Relocation Kit
Oil Catch Tank
HKS Racing Suction Intake Kit
Apexi Titanium 4” Racing Exhaust System
De-CAT Pipe
Mines Down-Pipes
Ogura (ORC) Triple Plate Clutch
Ogura (ORC) Lightened, Balanced Flywheel
HKS Intake Hard-Pipe Kit
HKS Intercooler Hard-Pipe Kit
Braided Coolant Hoses
HKS F-CON V PRO ECU – 5500rpm Launch Control – TR Racing mapped
Apexi AVCR Boost Controller – 0.7bar, 1.1bar and 1.5bar – TR Racing setup
D2 Racing Brake Calipers - 8-Pot Front, 6-Pot Rear
D2 Racing Brake Pads
D2 Racing Brake Discs - 388mm Twin Piece Slotted Rotors
D2 Racing Braided Brake Lines
HKS Hyper-Max 2 Coilover Suspension
HICAS Lock-Out Bar
AB-Flung Front Strut Brace
Cusco Rear Strut Brace
Arc Rear Anti-Roll / Sway Bar
Tein Suspension / Camber Arms
Cusco Solid Rear Sub-frame / Diff Bushes
Volk CE28N 19" Alloy Wheels in Black
Goodyear Eagle F1 Tyres All Round - 265 Wide Front & Rear
I haven't had her dyno'd yet, so can't tell you exactly what power or torque she is pushing out at the wheels or flywheel, only guess.
AH so your the owner of this beast, seen it down at TR and was saying to Rob one of the very few 32's i like, quality and fitting of the kit looked really good.
Tony
Discussion Starter · #8 ·
Tony
Yeah, that's me mate!
I wasn't looking for an R32 to be honest. However, this R32 jumped right out at me and bit me hard when I was looking for a new GTR, know exactly what you mean.
Discussion Starter · #10 ·
thats one hell of a spec for a mid 12 :S
Should get a lot quicker once you get the hang of the launches, or was it running quite low boost
I think a lot of it is relating to the fact that she isn't exactly a "light weight" GTR R32 - not stripped out at all, running full trim and weight plus the wide arch kit. Even the air con is still present.
Also running 19" wheels and road tyres.
Boost is set to 1.5bar, but peaks out at 1.7bar temporarily before it settles down.
I think the head winds at Santa Pod were quite strong on the Sunday as well.
I will be getting to another drag day before the year becomes a total wash out and will be happy if I can make it into the 11's.
I could also do with getting her dyno'd... if only I could find a 4WD dyno in my area.
1 - 10 of 10 Posts
