Administrator
Nissan R35 GT-R 07-16 - MVT Front Mount Intercooler Kit
£1,995.00
In stock
Add to Cart
Finance available on orders over £150
The power of MVT
‘MVT’ stands for ‘Multi Vane Technology’ and significantly enhances the efficiency of an intercooler, reducing intake temperatures and boosting engine performance.
Carefully shaped vanes located inside the charge air end tank distribute gases across the entire intercooler core, achieving significantly greater cooling efficiency than a system without MVT.
Performance enhancement
Research into other intercooler designs revealed that most systems have acutely angled end tanks with very poor air flow characteristics. They also channel most of the charge air (as much as 80% of it) through as little as 20% of the intercooler core.
Many aftermarket intercoolers are much larger than stock to increase core surface area and cooling performance. However, these larger designs often require further vehicle modification for installation, and can adversely affect air flow leading to poor engine running.
Japspeed’s MVT Intercooler for the R35 GT-R is a bolt-on kit that mirrors the two-core factory arrangement, and instantly increases engine performance without remapping.
Worth the wait
After identifying key weaknesses in other intercooler designs, over the course of two years engineers fine-tuned their new R35 GT-R intercooler concept using state-of-the-art CAD software, as well as Computational Fluid Dynamics modelling analysis, and 3D printing technology.
Not content with simply creating new vanes to control air flow, engineers also developed new cast aluminium end tanks with incredible air flow characteristics. Prototype MVT Intercoolers were tested for fitment and performance until engineers were totally satisfied with their revolutionary design.
MVT in action
Fitted with Japspeed’s new front mount MVT Intercooler Kit, our Nissan R35 GT-R showed a 30.7hp increase in engine power on the dynamometer, with output rising from 512.4hp to 543.1hp. This improvement in engine performance was achieved without any other modification to the vehicle.
Further analysis of our MVT Intercooler revealed a much greater maximum temperature drop compared with the standard GT-R intercoolers: 65.°2C for the MVT versus 41.3°C for the stock system. This 44.9% greater temperature drop highlights the supreme cooling efficiency of Japspeed’s Multi Vane Technology design.
Just as significant was the MVT Intercooler’s reduction in maximum pressure drop: 0.035bar for the MVT versus 0.043bar for the standard GT-R components. The MVT Intercooler’s 20.5% reduced pressure drop confirms the system’s ability to increase air flow through the intercooler, which in turn means more of the thrust produced by the turbochargers reaches the engine.
Under the microscope
Japspeed’s Multi Vane Technology Intercooler Kit is supplied as a direct replacement for the factory system, with no other modification required for fitment. The intercooler core and TIG welded end tanks are manufactured from aircraft grade aluminium, finished in black for even greater dissipation of heat.
Japspeed’s MVT Intercooler Kit for the R35 GT-R also includes high quality, four-layer silicone hoses plus all other ancillaries required for fitment. Japspeed’s MVT Intercooler Kit is covered by a lifetime warranty for maximum peace of mind.
Fitment
Nissan R35 GT-R 2007-2016 models
Skip to the end of the images gallery
Skip to the beginning of the images gallery
More Information
Part NumberJS024IC
Product CategoryIntercooler / Radiator
ManufacturerJapspeed
Intercooler / Radiator - Core Length (mm)280
Intercooler / Radiator - Core Width (mm)120
Intercooler / Radiator - Core Height (mm)245
Intercooler / Radiator - Overall Length (mm)395
Intercooler / Radiator - Overall Width (mm)130
Intercooler / Radiator - Overall Height (mm)410
Intercooler / Radiator - Inlet Size (mm)76 / 76
Intercooler / Radiator - Outlet Size (mm)76 / 76
Intercooler / Radiator - Hose Bore (mm)67-76mm (x 2) | 76mm (x 6)
Fitment PositionFront
Main ColorBlack
Secondary ColorBlack
MaterialAlloy
