This is a complete mounting kit set to fit the R35 GT-R Brembo brakes onto the older Skylines (R32, R33 and R34).
The Nissan R35 GT-R has huge 6 pistons front and 4 piston rear Brembo calipers paired with 380mm front and rear rotors.
The caliper brackets are CNC machined billet alloy using 7075 grade aluminum. The 7075 grade of aluminum is commonly known as "aerospace alloy" because it is used in the aerospace industry for its light weight and high strength qualities.
This mounting kit consists of:-
1) Front and Rear CNC machined 7075 grade aluminum caliper adapters
2) All required high tensile bolts and washers
3) Brake drum ring adapters for rear hand brake function (To be inserted into the bell housing)
4) Cone adapters for R34 fitment (14mm bolt holes). Not required for R32 and R33 fitment.
Recommendations:
1) We recommend using the 380mm front and rear brake kit for clearance issues.
2) Minimum wheel size for clearance is 18" with big allowance for BBK fitments. Examples are Rays Engineering Volk Racing TE37 and Nismo LM-GT4.
3) Fitment of larger BM-57 brake master cylinder for all R32 models. On the R33 and R34, only for the non GT-Rs.
Price of the complete adapter front and rear kit set is just GBP 1,050.
