1 - 9 of 9 Posts
Iv just brought a blitz nur spec cat back system the seller said its for R33/R34 after I payed for the item I then relised the R34 exhaust looks different to an R33 I hope it will fit?
I think it will fit the R33 but you will need a longer de-cat pipe, pretty sure the R34 system is shorter
Iv got a decat that i had extended as i did the same when fitting to my r33,
Can do for £40 posted?
Sam
Im not sure how long as i dont have standard cat to measure against, what i did was fitted the exhaust on all hangers and measure the gap left over and extended it using a welder. Wasnt more then a few inches
Sam
I fitted R34 system on my R33.
I needed small extension piece to be made up, or get a longer de-cat as mentioned.
1 - 9 of 9 Posts
