1 - 16 of 16 Posts
K-Sport 8 Pot Big Brake Kit - Skyline R33 GTR & GTS-T. Condition is New.
FRONT AND REAR AND CALIPERS AND DISCS
K Sport big brake kits provide the ultimate stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
The K Sport big brake kit includes:
8 Piston calipers front
4 piston calipers rear
Stainless steel brake lines
Machined aluminium hats
Carbon steel brackets
330/356mm Brake discs
The K Sport extreme lightweight caliper is machined from aircraft quality billet, weighs just over 2kgs each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
I PAID £2750
FOR SALE £1750 ONO
258308
258309
258310
258312
258311
Hi
Are these still for sale ?
Steve
1 - 16 of 16 Posts
