any body heard of these ecu have been offered 1 for my r32 gtr are they any good and much better than standard if it helps all the seals are still intact cheers
Its a reflashed OEM ECU with their map installed. i imagine it would be similar to the MINES. NISMO versions so mapped for 100+ Oct fuel. You may have to retard your timing to avoid det damage if you use low grade fuel.
Incidently, I now offer a remapp service for 32/33 ECU's to suit UK/European fuels which offer similar performance but without the risk of detonation damage. It also removes speed limit and boost value is increased along with fuelling and timing detail.
DaveW
