I looked all over for information on this controller but could find much. I have a few questions that i hope some people can answer for me.
- Does this controller bypass the G-sensor or bend the signal?
- Some people were saying that their ABS warning light whent on when using the kansai ETS. Did anybody here have that.
The reason i am interested in this controller is because it can make the atessa go into a fixed 50/50 or 40/60 mode. That should make for a easier drive in rainy conditions. For reference i own a 600HP non-Vspec BCNR33.
i don't own one of these, but i would think it tricks the system into thinking it has a constant G input so the front torque is always their. maybe someone will correct me on this but i don't think you can run any TSC without a G sensor, so it cant bypass. If the g sensor is removed the ABS lamp will come on, maybe this is why?
just my thoughts, hope it helps.
Already installed it but haven't tested it to see how it compares to the Do-luck G-Sensor that i got in it.
