KVT-725DVD TFT touch-screen receiver & remote control
KVT-725DVD main features:
The Kenwood KVT-725DVD offers a complete touch-screen control centre for your car's multimedia system
Enjoy watching DVD movies on the 7 inch TFT colour screen. Or add a rear screen and the kids can watch a movie while you listen to the radio or use navigation in the front (navigation computer optional extra)
7 inch (154 x 87 mm) widescreen TFT touch-control display (336,960 pixels)
New fully-automatic "Z-action" open / close mechanism with motorised tilt angle adjustment through eight steps plus motorised backwards / forwards adustment through four steps
Partially detachable TDF screen panel with DSI & security code anti-theft protection
Video disc playback (DVD & V-CD compatible)
MP3 (with ID-3 tag display) and WMA file compatible
Dolby Digital DRC (dynamic range control : wide/ normal/ midnight modes)
Equalisation (Bass / Treble / Q Factor / Gain Control) and Voltage / Current / Temperature / Fan speed display
Rotary volume control. Red or green (switchable) button illumination
Radio can be connected to factory-fitted remote controls and external dashboard displays on most cars (adaptor required)
Compatible with current model Kenwood CD / MP3 changers (control for two changers or one changer and auxiliary input)
One RCA AV Output (PAL or NTSC according to the source)
One RCA AV Input (PAL / NTSC / Automatic format selection)
Video 2 input signal has automatic detection mode (Normal / Auto)
Rear-view camera connection ready (through AV Input)
RGB input for compatible navigation systems
Infra-red remote controller included
DVD ± R/W, CD-R, CD-R/W compatible
Display of CD text information from head unit or compatible CD changer
Disc Name Preset allows names to be assigned to discs in optional CD changer. When disc is selected the name will appear on the radio's display
Disc Name Preset Play allows you to select by name any disc in optional CD changer by remote control
RDS (radio data system) & EON (extended other networks) tuner
Full coverage of LW / MW / FM wavebands with 24 presets
Display of radio text information
4 x 50 Watts max power (MOSFET)
System Q preset sound control system
BMS external amplifier control
System E+ provides high-pass filter and bass boost with phase inversion for improved bass frequencies. Front and rear speakers can be individually adjusted
Switchable dual-zone allows playing different sources to front and rear speakers simultaneously
Three gold plated RCA preouts (5.0 volt) for connecting external amplifier
24 hour clock display
Two way telephone / navigation mute
Complete with full fitting and operating guide
KVT-725DVD What's in the box?
KVT-725DVD head unit and mounting sleeve
Control box with mounting brackets
Connecting bus cable for control box
Primary power cable
Secondary power cable
Fascia trim
Front panel carry case
Remote control
Owner's manual, radio passport & warranty card
£430 delivered, no offers!
Also, there's still another 2 months warranty remaining with Kenwood!
N.B. My DVD is identical but some of the silver plastic is black. I can get a picture on here if required.
