161 - 179 of 179 Posts
Discussion Starter #164
Yesterday started the car it runs good idle at 1200rpm throttle response is verry nice only downside when you rev it the idle will hunt arround for 10seconds and than comes back to normal .
I also found that when I tried to adjust the idle screw best idle is when screw full closed .
is this normal with apexi power fc or not ?
Discussion Starter #165
Made a leak tester this afternoon, blocking off the second turbo with a S1000RR oil filter works good :p
Found alot of leaks at the tubing and even sensors.
What do I do with the last pic ? let it go back to the engine covers or block it completely ?
257798
257799
257800
257801
257802
Discussion Starter #166
templates made
257850
Prepreg cut
257851
First layer of prepreg down
257852
257853
second layer down and droptesting to see if I got full vacuum
257854
Baking time
257855
the next morning all cooled down
257856
unwrapping is so much fun but terrible for the nerves to see result !
257857
Removing more and more
257859
257860
Discussion Starter #170
clearcoated
257990
257991
257992
257993
257994
Only issue didn't let the seems line up this time.
If I ever make second one this wont be happening again
257995
Discussion Starter #176
looks good straight out of mould no pinholes just remove flashlines and buff the releas agent off and ready to go
258674
