1 - 12 of 12 Posts
Hi all, I've finally gotten around to introduce myself properly to the forum. My love for Skylines started when my mate, a fellow forum member(Natbrat) who most of you may know well took me for a ride in his beast and I thought damn, I've gotta get me one of those. Uh that coupled with a minor midlife crisis,lol. I've had my r32 GTR now for just under a year now and have been constantly making improvements as time goes on.
This is the current spec:
Exterior:
•Sparkling Silver KL0
•Nismo front bumper with N1 vents
•Nismo side spats
•Nismo rear lip
•Nismo bonnet lip
•Trust rear spats
•Supaguard under carriage protective coat
•SARD front license plate relocator
Engine/Management:
•Dyno proven 550bhp
•HKS Signature T51S Kai single turbo conversion (low mount)
•HKS full engine gasket set
•HKS 2mm head gasket
•HKS Special Racing Wastegate with HKS screamer pipe
•HKS Spec Core FMIC
•HKS Intercooler piping
•HKS Kyushu custom inlet manifold piping
•HKS AFM delete pipe kit
•HKS IN/EX cam gears
•HKS Forged Pistons
•HKS 280l/h fuel pump
•Tomei fuel rail
•Tomei Master cylinder stopper
•Tomei strengthened Valve springs
•Grex/GReddy Oil filter relocation kit
•Grex/GReddy 10 row oil cooler
•GReddy Pro Cams IN264/EX272 (10.1mm lift)
•Trust/GReddy Airinxs intake kit
•Trust/GReddy GT Inlet wastegate
•Trust/GReddy ISO Iridium spark plugs HR-8
•SARD Type FJ Racing Type Fuel Pressure Regulator
•SARD 800cc injectors (lime green)
•Splitfire Coil packs
•Nismo strut tower bar
•Nismo Engine mounts
•Nismo timing belt
•Power Enterprise p/s, air con and fan belts
•braided lines throughout engine bay
•mapped at 1.4bar low boost/1.65bar high boost
Interior/Styling/Electronics:
•Bride Brix II semi-bucket seats (driver & passenger)
•Sparco Silver ltd. edition 4 point camlock racing harnesses Driver & Passenger
•5 point roll cage with removable cross bar
•Sparco series 323 330mm suede steering wheel
•N1 320KMH speedo cluster
•GReddy Profec B ltd. edition boost controller
•Apexi Power FC D-Jetro and Hand Commander
•HKS 3 DIN cluster…
•HKS Oil pressure
•HKS Oil temp
•HKS Water temp
•Skylab Torque Split Controller (located in center console)
Handling/Powertrain:
•Cusco fully adjustable coilover suspension with pillow mounts
•Cusco front upper/lower tie rods
•Full R34 GT-R Brembo brakes F&R
•Goodridge braided brake lines F&R
•Nismo front strut tower bar
•Nismo solid short shifter
•Nismo 2 plate Lightened Flywheel
•OS Giken TS2B Twin plate clutch
•Rota 17'' alloys
Some of you may have already received posts from me and I've purchased a few bits from some of you all. I have to say that it all has been very positive so far and I've enjoyed being a member of the Skyline community. A big thumbs up to Nat(Natbrat) who I've relied on for advice and his expertise(probably bordering on being a pain!lol)
In the upcoming weeks I will be looking at getting the car ready for the summer and will keep you posted on the progress. Thanks a lot guys.
Thanks guys. I'll work on getting some better pictures up soon. Gotta few things planned for her. Gonna get her into Ron at RK this week to change the cam belt as a precaution and delete the hicas and pretty much give her a proper once over.
Yes mate, as long as I'm not working that's the plan! I intend to go to as many meets as possible and enjoy her as much as I can as last year I was just too busy.
An impressive spec list indeed.
That T51 must be addictive..
My mate has the T51r BB Kai turbo with the GTII wastegate on his RX7 and making about 360hp at 0.7bar iirc.
Had a wee shot, its mental when the boost and screamer comes in :D
Discussion Starter · #10 ·
You're not wrong there mate. When that turbo kicks in you get such a rush! And the sound is just awesome. I was instantly hooked. Took it into Ron at Rk today so really excited a out getting it back after he's given it a thorough look over. The nismo timing belt is about 5 years old too so would just feel better knowing that it's changed. It would be just my luck for the forbidden to happen! Went for an hks one this time as I thought it would look best with the hks cam gears.
1 - 12 of 12 Posts
