arc intercooler 100mm lightweight version with hard pipes for single turbo and greddy typr r will fit r32/r33/34 (does not have inlet temp sensor in the back) i will only sell as a kit £700
r32/r33/r34 alcon 355mm 4 pot brake kit very slight lip on disc pads life about 40% left not warped drive and work perfectly £700
rb26 cp forged piston 86.5mm new in box include pins and rings £500
rb26 cosworth forge conrods new in box cost £800 only £500
nagoya engineering r34 long nose lightened and balanced crank just polished by Anderson race engines at the cost of £150 standard size no damage £500
tomei pro cams r34 gtr 270/10.25 set of inlet and exhaust new in boxes £450 r34 cas £100
tomei 1.2mm 87mm head gasket with restrictor new £130
arp head stud kit for rb26 £130
tomei conrod stud kit for rb26 stock rods £100
r32 set of greddy pulleys X2 £120each
tomei sump baffel kit £100
trust complete sump extension kit(7 litres) on sump with r33 diff complete £350
hks single turbo manifold completely re tig welded no cracks £450
hks gt1 60mm wastegate £300
r33 gtr complete power steering pump with pipework and mounts to relocate res to front slam panel for single turbo £70
r33 gtr rb26 head no cams very good condtion £400
r34 gtr rb26 head no cams very good condition £400
r33 rb26 block stock 86mm no damage good condition £350
r32 rb26 bolck bored to 87mm good condition £150
polished inlet manifold £100
sard frp genuine x2 £60 each
nismo frp fits in stock rail £40
hks twin power £150
jun oil pumps x2 £350 each pm me i will open them and get pics
yannak r33/r34 gtr rear camber arms £60
yannak r33/r34 gtr rear traction arms £70
jic front 32/33/34 tension/caster arms £50
3 defi bf 60mm gauges(white backlight) with controller and sensors boost water temp fuel pressure
2 sets of 4 blitz mirror face gauges one blue one red with all wiring and sensors £250 each set
brand new os giken clutch twin plate will fit r32/r33 gtr (with push to pull conversion which i may have one i think) £1000
everything is plus post
no paypal due to the scammers on here
would prefer pickup so everyone can inspect before buying
please pm me for more info or pics
thanks
hks twin power £150
thanks
