Since replaced turbos as upgrade to 2860's for more power (400-470?) car developed leak from top rear r/h side (turbo side) of engine.was first thought to be oil so had rocker seals and half moon replaced but did not cure. On futher investigation appears to be water (coolant in overflow low in 1 week) and it looks like rear core plug at top.Is this common for these engines when upping hp or could it be leaking from head gasket?
