Hi Guys
Im looking for a bit of advice. This morning my drivers side front tyre showed low pressure. I looked at the Tyre and there is a split in the rubber below the valve cap. Think i may of damaged it when cleaning the wheels.
The Tyre was completely flat so i took the wheel off and took it to Kwik Fit to get it repaired temporarily. They changed the valve to a rubber type one as a temp fix. I just wanted to know if this is safe to use until i can get a replacment TPMS sensor fitted/paired.
Neil
Neil
