I have just finished my rb30/25 det.
Mods are:
550 injectors
walbro intank pump
gready plenum
holset hx40/35 hybrid turbo
using standard r33 airflow meter for the moment
datalogit
lc-1 wideband
My problem is I have a misfire along with running lean up untill it comes on boost ( not running big boost 0.3 bar).
I have started to scale my airflow meter and it does help.
What I want to know is because I have changed the turbo to a bigger size would it throw out the map and make it lean as I am seeing at the moment.
Surely the airflow meter is seeing a certain amount of air and adding the required fuel.
My a/f ratio on my logs are way to lean compared to the map.
It's as if I'm not getting enough fuel and I'm running lean throughout the whole map.
Do I need to rescale every bit of my airflow voltage?
Any help please.
Mods are:
550 injectors
walbro intank pump
gready plenum
datalogit
lc-1 wideband
Any help please.
