hello it is for seeing if they can help me as I can install an external gasoline pump in my r-34 in the gasoline tank I have one walbro 255lbs and the one that I want to isntalar external she is one bosch 044 but I want that the two work to have major security with the gasoline and not like putting them the two wing time that if in individual lines only I only want q one in the fuel rai.disculpen by my writing is translated by Alta Vista.
A Walbro should feed an external, swirl pot fed 044 pump fine, as it isn't having to produce meaningful pressure, just flow.
walbro separately goes in a line aside from bosch 044 external two lines but I want to see imagnes of instalciones of external gasoline pumps if they can help me with that information
