41 - 60 of 60 Posts
Discussion Starter · #44 ·
yes, still have both, am on friends pc, mine is knackered, but you can call me anytime 07515 413343 and leave a message if no answer.
cheers :)
Discussion Starter · #46 ·
bonnet provisionally sold.
steven, where is it located? is it the one that sits on top of the engine towards the rear just by the rear coil pack? if so, its gone sorry.
cheers
Hi, what are the specs of the rims in on the R33?
Are those 18" or 19"? 9J? Offset? Tire size?
I looking for a nice rims for my 1996 R33...something similar to what you had or have.
Did you have any problems with tires rubbing against the fenders? I gather if you had no problems then I should either.
The rims I want has the following specs: 5/114.3 18X 8J +40
I'll appreciate the info.
Thanks, Bevan
Discussion Starter · #56 ·
Hi Bevan,
i think your offset of +40 is way too much, most common is +12 or +15.
my wheels were 5x114.3mm pattern, and were 19x10" with an offset of +25, but i used 10mm thick machined hubcentric spacers (and longer studs), to bring the offset down to +15. the front tyres touched the arch liners on the inside, but only slightly, on full lock.
tyres were 265/30X19.
cheers, ian :)
41 - 60 of 60 Posts
