1 - 20 of 40 Posts
Just had the stage 1 done last week at Litchfields, thought it was fast as standard but FFS it's crazy fast now, what a difference, feel sorry for the tyres now. ((-:
Do you know which boost you are running now?
You have full exhaust or just Y pipe?
I am really becoming confused because I have COBB, full exhaust though, and K&N filter panels and my injectors were being maxed at even 15 psi (IDC 98-99%)...
I am running 14 psi boost now (custom map) and my IDC is 96% which is acceptable...
Are you running much leaner AFR or my OEM injectors are faulty?
I had mine done a few months back and it does make quite a difference. What tyres are you running? Im on the oversize mpss and struggle for traction in 2nd gear in the dry! I have to keep the tc in R mode now or it keeps cutting in and killing the power.
Discussion Starter · #11 ·
No issues with injectors, runs great at 1.1 bar.
Discussion Starter · #12 ·
I'm on the over size MPSS .
Graham, you should have had injectors and downpipes and mapped at 1.3bar, that will bring a smile to your face.
When you see the Mostly Autumn crowd let them know I will be at The Stables for the MK gig in December. If Bryan gets up to MK in the afternoon and wants to go out for a go in the GTR drop me a PM.
I've got a milltek race plus exhaust with Y pipe and stage 2 installed from litchfields. I don't overly understand the different maps as I have to change what octane of fuel I'm running within the coolant data.
For example: if I ran on 95 does that mean I'm on standard boost? And 99 max boost? Or am I just running max boost all the time??
I previously had stage 1 and had the ability to increase/decrease the boost, never had to change octane.
Jonny
You can run whatever boost on whatever fuel map. It just takes into account the fuel octane so it will run safely.Obviously there will be a loss of power the lower the octane.
The old stage 1 only let you adjust the boost.
Okay, so how do I set the boost per map? I wonder what litchfields set them as ?! :S
Discussion Starter · #20 ·
Hi Barry
It's silly fast now, poor tyres struggle for grip as it is, will tell Bryan your at MK and will let u know what he says, get Livvy over the bonnet for a photo or two:smokin:
Graham
1 - 20 of 40 Posts
