The wiring that comes from the bottom right behind the boot cover and then splits feeds to the spoiler one way and boot lock the other I would have though must have a permanent feed for the solenoid.
If you undo the boot cover clips which will take a matter of moments should find out with a multi-meter in no time to confirm. If it has a live, disconnect the block and take a feed from the lock side when the block is unplugged it's irrelevant then whether the battery is connected or not as you've disconnected that block. Then just plug back in after.
