Cusco front alloy strut brace
Aircon dash unit £35
Drivers door switch panel £25
C02 exhaust sensors X 2 £60
Standard Injecters £80
Temp sensor in the dash by the base of the winscreen £25
Aircon heater sensor £25
Boot cable £25
Speedo cable £45
Engine mounts £50
Brake master cylinder £45
Clutch master and slave cylinder £35
4WD / Hicas ecu's £50
Steering rack £60
R32gtr rear diff [4.11] minus the input shaft / flanges £100
Front lights X 2 £140
Full lock set with gtr key £70
Drivers side rear quater panel card £25
A pillar trim X 2 £20 each
B & C pillar trim X 2 £20 each
Boot trim and carpet £50
Steering column / ignition barrel plastic cover X 2 £25 each
Center consol lid £20
Driver side soft rubber door seal £25
Soft rubber boot seal £25
Drivers side dash vent £15
Ash tray £15
Standard steering wheel £40
Starter motor £50
Aircon pump £40
Power steering pump £40
Wiper motors front and back £20 each
180mph Dash clock cluster £80
Cam angle sensor £70
Standard jack £20
Front suspension arms £20 each
Battery £10
Screen wash motors £10 each
Alternator £50
Knock sensor X 2 £50 each
Space saver wheel £25
Wheel speed sensors X 4 £40 each
Front drivers side wing £50
Bonnet £150
All prices plus delivery
Neil
Boot cable £25
Speedo cable £45
Engine mounts £50
Steering rack £60
Ash tray £15
Starter motor £50
Aircon pump £40
Standard jack £20
Battery £10
Alternator £50
Bonnet £150
Neil
