Lots of spare parts R32gtr / R34gtr
11K views 48 replies 31 participants last post by  Yvo
#1 · (Edited)
Nissan jack £20
R32 GTS Driver side front wing £100
R32 GTS Bonnet latch with bracket £100
R32 GTS Speedo cluster £80
R32 GTS interior bonnet release catch and cable £40
Front bespoke towing eye £20
Intercooler / engine silicone hose / pipe £20
Radiator top bracket £10 each
Radiator low mount rubber £5 each
Stainless steel turbo shield was fitted to a T78 £20
R34 GTR bespoke ally swaged rear interior quarter panel for a track car £60 the pair
R32 GTR Center console opening compartment £40
R32 GTR Door boot rubber seal £40
R32 GTR Passenger window rubber seal £40 SOLD
R32 GTR lower center console £100
R32 GTR round adjustable blower vent £40
R32 GTR Upper steering column cowl £20
R32 GTR Lower steering column cowl £20
R32 GTR Door sill trim £30 each
R32 GTR Boot shut plastic trim £30
R32 GTR A pillar plastic trim £30 each
R32 GTR Glove box £30 SOLD
R32 GTR Metal door / roof trim £125 each
R32 GTR Scuttle panel £50 SOLD
R32 GTR Parcel shelf £40
R32 GTR Interior rear quarter panel £40 each
R32 GTR Interior carpet £250
R32 GTR Driver side kick panel £30
R32 GTR Passenger kick panel with flare £40 SOLD
R32 GTR Indicator stalk £40
R32 GTR Heated screen switch £40
R32 GTR Hazard switch £40
R32 GTR Rear wiper switch £40
R32 GTR Window / wing mirror master door switch panel £50
R32 GTR Upper speedo surround with no switches £30
R32 GTR Full Speedo surround with all switches and clock £100
R32 GTR Speedo cluster £150
R32 GTR Climate control unit £100
R32 GTR Speedo cable £50
R32 GTR Clutch peddle / box £60
R32 GTR Brake peddle / box £60
R32 GTR Accelerator peddle £40
R32 GTR Interior bonnet release catch abc cable £50
R32 GTR Rear brake / driving light £75 each
R32 GTR rear number plate light £10 each
R32 GTR Bonnet latch £50
R32 GTR Ignition barrel door locks with GTR key £150
R32 GTR Attessa 4wd pump £250
R32 GTR Rear windscreen £200
R32 GTR Attessa 4wd abs ecu £50
R32 GTR Cam angle sensor £100
R32 GTR Abs pump £100
R32 GTR Abs pump bracket £50
R32 GTR Air con compressor £150
R32 GTR Air con compressor bracket £50
R32 GTR Clutch master cylinder / servo £80
R32 GTR Brake master cylinder £60
R32 GTR Rear windscreen wiper motor £50
R32 GTR Exterior door handles £30 each
R32 GTR Gearstick £40
R32 GTR Reverse / fog light £40
R32 GTR Power steering reservoir £40
R34 GTR Center console opening compartment £40
R34 GTR Yaw sensor £
R34 GTR Cover £
R34 GTR Steering rack clamps £10
R34 GTR Steering rack cover / guard £20
R34 GTR Power steering pump and bracket £
R34 GTR Plastic foot rest £30
R34 GTR Boot shut plastic trim £40
R34 GTR interior door handle £30 each
R34 GTR Power steering rack £500
R34 GTR Adjustable steering column £150
R34 GTR Oem rear windscreen £250
R34 GTR Indicator stalk £60
R34 GTR wiper stalk £60
R34 GTR Bonnet latch with mounting bracket and horn £150
R34 GTR Leather gearstick gaiter £20
R34 GTR Passenger dash air bag £70
R34 GTR Heater blower matrix box £100
R34 GTR Air con compressor and bracket £150
R34 GTR Ally air con pipes x 2 £40 SOLD
R34 GTR Abs pump and bracket £150
R34 GTR Black leather with red stitching handbrake and cable £60
R34 GTR Front wishbones £300 the pair
R34 GTR Rear bumper support slam panel £400
R34 GTR Attessa hicas 4wd pump £300
R34 GTR Attessa pump reservoir and pipe £50
R34 GTR ash tray £40
R34 GTR rear number plate bracket £40
R34 GTR Boot latch mechanism £60
Pics to come
All plus P&P
Neil
See less See more
#4 ·
Nissan jack £20
R34 GTR bespoke ally swaged rear quarter panel for a track car £60 the pair
R32 GTR Complete boot trim (sides not the carpet) £250
R32 GTR Bonnet catch with bracket and horns £150
R34 GTR Ally air con pipes x 3 £40 each
Pics to come
All plus P&P
Neil
#24 ·
Hi Neilo.
Would you have pics of these please.. Very interested.
Hi Neilo.
#23 ·
Is this the panel that covers the ECU?
Would also be in interested in the rubber seal for the passenger window, as the rear top corner on mine is torn and catching the glass if the door isn't opened before shutting the window.
Are both parts in good condition without cracks/tears?
If so, how much would it be including postage to HS2 0ED?
Kenny
