hi all
past couple of day I notice the oil temp is on the lower side,
during normal city driving temp was only at 72c. which usually should
be around 85plus ? it stayed at the same level when gearbox temp at
87 plus n water temp at 90. oil pressure seems normal n plus in the
assessport to varify ecu reading was same as the digital gauge.
can't be normal? pls advice btw. no error code or warning lights.
thanks
winsome
thanks
winsome
