I am planning to run a Z32 AFM in my ER34 and will be fitting in a Power FC. I've also got lying around the MAP sensor for the Power FC that would enable the ecu to read boost reading.
My question is, is there anything wrong with concurrently running both MAP & AFM? Or should the Z32 AFM be discarded and just run on MAP?
Pretty blur on this. Appreciate any comment/info appreciated.
