the heavy one just sounds like a better car; twice the power with same ability to go round corners ( g's ) and later on i think we've talked about giving it the same ability to stop , we've almost completely counteracted all the ill effects of being heavy.Mycroft said:2 cars... 1 weighs 1 tonne the other 2 tonnes they both have equal power-to weight ratios and torque curve/gearing coincide exactly for each... they are perfectly matched... even down to the 'G' force each can generate in any given curve...
Mycroft said:You are almost there Rev, but now, if you can, put in the cornering G force at 1 'G' to both... you may have to increase the tyres to 265s' to get equal cornering 'capture' speeds... and the bigger car eats the smaller one...
Because the heavy car will have a greater 'over burden' of power during any incremental speed it will almost always accelerate quicker for the same PtW ratio...
To corner a bigger car at 1G will mean that it will have huge reserves when in transition to the straight [I did mention this earlier] something like 80% greater adhesion in that transition...
For the heavier car to be slower in any corner would mean that the 'G' forces cannot be equal...
You must also ensure that the 2 tonne car can brake equally quickly, that means the singular factorial number must be upped to compensate... both cars must be able to generate equal 'G' in the braking too... do all of that and the 2 tonne car positively swamps the lightweight...
In a race the 2 tonne car will eat the 1 tonner... quite easily....
NotoriousREV said:However, given the choice of Bentley Continental or Lotus Elise as my trackday car, I think Norfolk's finest would get the nod over Crewe's effort.
That is not the point of either the original question or my reply... ignore 'Elise vs Bentley' etc... that is not what is in question here... so both quotes are equally valueless.LSR said:To end the matter, a race around a track between a Lotus Elise and Bentley of some sort ended in the conclusion that the Elise ate the Bentley on the corners (that is what actually happened).
No, not strange at all... he has rules to abide by and is also not building 'equal' cars, add to the saving of fuel... the list is endless... the question was... is there any advantage that a heavy car has over a light one... and given equal PTW ratio and equal Cornering powers... ie able to turn a whole circe at a given 'G' and Simon is again getting closer....Mungo said:Strange how every competition car designer is reducing weight at every opportunity. How little do they know
I can think of a lot of disadvantages for a heavy car, but I can see how it can do a 360 degrees circle at any given "g", due to lateral g's etc.the question was... is there any advantage that a heavy car has over a light one... and given equal PTW ratio and equal Cornering powers... ie able to turn a whole circe at a given 'G' and Simon is again getting closer....
You could ask the chap who posted immediately after you [by PM preferably] as I can hazard a guess that 'SDB'... does not mean Simone De BeauvoirLSR said:Mycroft,
Why did you get banned from scoobynet? I haven't seen any of your sure-to-be controversial posts over there. I should have asked this in my last post as I can't weight, sorry wait (pun) for the answer.
Yep...SDB said:As I understand it the question was whether a heavier car corners and brakes in a more performant way than a lighter car.
It is not a loophole... it is merely an example...SDB said:Whilst there is indeed a loophole in Mycrofts original reply that makes him correct in what he says.
There is the rub... ''all OTHER thing being equal''... I contend that lightness just makes a difficult task easier... in simple terms getting a 1 tonne car to corner at 1 g is very much easier than to make the 2 tonne car do the same trick... but if you manage it then the heavy car will beat the light one.SDB said:In answer to the actual question of this thread (keeping within the spirit of the information was actually requested), and without deliberately attempting to confuse people...
All other things being equal, a lighter car will (in almost all circumstances) be able to corner and brake more performantly than a heavier car.
I am not sure of your point here... none but a fool would construe that the objective in competition was to make a vehicle heavier than the rules allow... that is why I prefaced my statement with 'No, not strange at all'... it was not a statement advocating that Motorsport cars should be heavier... but in subtle ways they do... much of the gains found in a weight class are found by moving the weight around... much as Pilots will trim their craft by moving fuel around designers can gain from circuit to circuit by doing the same.SDB said:Mycroft...
you wrote "he has rules to abide by " in response to a question of why do motorsport teams attempt to remove weight from their competition cars.
In all except the very unusual of circumstances, the rules regarding weight in motorsport are minimum weights, not maximums.
Are you suggesting that the manufacturers of race cars would rather make their cars heavier than the competition?
