greddy r32 gtr pulley set good condition £120 +post
hks ssqv with gold insert on r34 neo crossover pipe £60+post
r33 gtr gear box from 1996 lm 58,000kms £300 comes with transfer box and shifter
r32 gtr gearbox come with a car blow engine never tested £150 comes with transfer box no shifter
sports comp tacho with shift light £40+post
sard 280litre pump £60 with custom pick up sock
walbro in line pump with -6 male ends fittings £40
hks purple oil cap small mark can hardly see it also box says mazda but it for an rb26 £60+post
apexi water swirl pot fron r34 £45
sard water swirl pot with greddy t piece £60
4x blitz carbon mirror face red back light gauges boost water oil press and oil temp comes with all sensors £290+post
4x blitz carbon mirror face blue back light gauges boost water oil press and oil temp comes with all sensors £290+post
3x defi bf gauges white back light boost water temp and fuel pressure line 2 controller fuel pressure gauge has small dent in the surround hence comes with all sensors £250+post
line lock for burnouts with wiring swtich and pipes ready to fit £100
custom alloy hard pipe kit from r32 gtr with trust type r bov single turbo £150
custom hard pipe kit come off my time attack r34 single turbo t88 with trust type r bov £200
custom hard pipe kit r34 gtr again with trust bov car was twin turbo £150
r32 gtr alloy breather tank fits infront of battery £45+post
alloy battery insert and relocate to behind drivers seat?boot lines with earthing kit £35+post
sard genuine fuel pressure reg £60 only one outlet fitting
greddy oil cooler kit will fit rb25 and rb26 £180
hks custom twin oil cooler set up this was used with intercooler mounted under the slam panel comes with relocation/sensor block,lines and fittings £300
custom radiator from and s15 with billon fan controller kit could be made to fit r32/33/34 quite easy £300
x2 r32 4wd pumps £60 each pics to come
r32 gtr nismo/tomei rear diff looks like adjustable version £300 pics tomorrow
r33 gtr nismo fully adjustable 100% non v spec lsd £350 pic up tomorrow
rb26 cam covers all need paint clean etc 3xpairs £50 each pair 6x front cover £20 each 2x centre cover £15 each 3 inlets £30 each
greddy bnr34 alloy top radiator pipe as new £60
ap bias brake front to rear valve £50
nismo complete rear subframe bush set from r33 gtr subframe bushes diff bushes inner lower arm bushes £200 the lot new
nismo engine mounts and gearbox mount and cradle insert from r33 gtr 58miles old £100 +post
sorry about the blurred pic
blitz machnincal boost gauge with warning shift light and exhaust temp gauge £60 +post
r32 front bumper bar with n1 cut outs
r34 gtr rear diffuser
r34 top secret repaired titanium exhaust
all to come
no paypal bank tt or pick up prefured and everything is plus post pm for question i will try to get back to you asap
all to come
