assuming that you've replaced the stock turbo with steel turbines versus the stock ceramic units (and so in theory you can't snap the blades off), how much boost can you push through them before efficiency levels off? N1s go to 1.4bar, but they're ball bearing. How much do journal bearings take away from the amount of boost you can efficiently make?
