1 - 6 of 6 Posts
Can this be done as standard on a gtr or do you have to buy extra sensors?
Check out the got boost kit , it about half the price of the one in your link, looks good quality as well.
I used a differential fuel pressure regulator.
Since you have a rising rate fuel pressure regulator, you can measure the difference between engine boost and fuel pressure to show the fuel pressure across the injectors, using this will improve the quality of the fuel delivery to the engine.
Not all ECU's are able to usefully use this information though.
On speaking to Iain at litchfields today , there are about to release a fuel pressure sensor that is plug and play into ecutek.
1 - 6 of 6 Posts
