I currently have a 2009 with a Litchfield stage 1 tune and so already has the Milltek Y pipe, can I add the Milltek secondary cat back exhaust without causing any issues? would I need a retune?
Its still a little bit to quite for me with just the Y pipe.
Yes you can add that without issue, you only need a tune if removing down pipes or swapping out the cat back on a 2017+ as they have a valve.
I was the same I went stage 3 but only for few months then I went 4.25 with the downpipes purely for some drama.
