There is a seller on ebay.I can't help you with where they go, but where did you get them from?
Nice one thanks NozzaHere you go, instructions...
http://www.gtr.co.uk/forum/117792-mines-cam-baffles-installation.html?highlight=Mines+cam+baffle
Stock separator is not to be used.You were also confused, do you use the stock separator or not?
Also the movement of the cam baffle plates from 3-4 to 7-8? on both inlet and exhaust or just exhaust as per the picture?
I dont have the stock seperator either.I couldn't find a way to use the stock seperator. Ended up ditching them. I don't see how they can make a big difference if you already have the foam bits in them.
