All,
I've got a small problem with my R33. It seems to be that when cold it wil not pull away cleanly. This occurs for between 2 and 5 minutes depending on driving conditions. It then seems to disappear. However, occasionally the car feels sluggish above 5,000 rpm when warm too.
Just wondering whether the car needs an ECU reset or something similar. It's been serviced at Middlehursts, and last time they could not detect a fault!
There is definitely something amiss, but I'm not sure what.
Is it sensible to reset the ECU? How do I best go about it? If this causes no change, I suppose that new plugs and leads would be advisable.
The car is using little or no oil, and head gasket seems fine as there is no contamination that I can see.
Any advice would be gratefully received.
Matt
Matt
