Hello everyone I finally decided to make a profile here. I'm having a little problem with my car recently. When ever I start it up in the morning, when it's colder, the car would misfire for a while then go to a normal idle.
It would sound like a boxer engine. The weird thing is that it is intermittent. Sometimes its for a while, sometimes it doesn't do it at all.
Any advice/suggestions are appreciated.
Try new plugs.
Check coil contacts for corrosion.
Then start looking at injectors.
I had issues with ID1000's seizing up after being stood for a couple of months.
Plugs is the easiest thing to sort first. My 33 used to do the same and plugs swap out fixed it. When were they last changed? How often is the car used?
