1 - 9 of 9 Posts
Thinking of running theses any problems with tyre pressure sensors and should I use nitrogen or just normal air.
Cheers shed
No issues with TPMS mate and I run normal air without issues as a lot of guys on here do.
I have mine at 34psi cold, any lower and I found them over bouncy at higher speeds..
Personal preference tho, great tyres in wet and dry and they seem to be quite hard wearing as well.
+1, I started out at 29psi and felt the car was easily unsettled on uneven surfaces, 31psi was better and now 33psi is the best so far; also much improved ride comfort. Going to try 34psi this week
you are doing the same experimentation I did
check it here -
http://www.gtr.co.uk/forum/211961-recommend-tyre-pressures-mpss-2.html#post2409145
and I'm still on 34psi cold
ok over the last few weeks I have been experimenting, ive got 275/305 and it really does seem to help with keeping the tail to the tarmac, wet grip i find 100% better than the bridgestones
All cold psi -
32 bouncy but comfy no comfort mode needed
33 comfy not too bouncy!
34 harder with minimal bounce , need to use comfort if want soft ride
35 hard, looses the comfort of the ride for me
I'm staying on 34 for now..
Wish I'd seen your post earlier, would have saved a lot of uncomfortable test runs! :)
are you on a my09/10 suspension or my11+?
my09 ... well overall its personal preference.. that's what was best for me... so some testing to see what psi is best for you is a good idea..
1 - 9 of 9 Posts
