Owned for 6.5 years bought as Litchfield stage 4.5 and built by JM imports. Very reliable fast road built with no expense spared. Full spec below Price 70k
Link
Wheel Tire Car Land vehicle Vehicle
3.8 ENGINE –JM forged engine
CP pistons
Carillo rods
Block honed
Oem engine gasket overhaul kit
X16 new oem headstuds
Millers csf competion oil
Hks oil filter
Complete bottom end kings bearing kit
JUN 264 in/ex camshafts
Oem headgasket kit
Cnc heads balanced + crank
LM 7163 complete turbo kit
ETS race intercooler
ETS IC piping kit
Akropovic 90mm exhaust
Akropovic y-pipe
LM intakes
Gotboost speed density kit
4 bar ams map sensor
Fore innovation triple fuel pump
ID1700
Syvecs s6 plus
Syvecs fuel pressure sensor
GFB bov’s
new lamda sensors
Willall extended sump
8mm Fuel lines
T1 fuel rails
Flex fuel
Syvec AWD controller
GEARBOX –
pp6 1-6 gears
ppg output shaft
linney a and b billet baskets
linney 16 plate clutch
linney fwd clutch
linney circlip upgrade
jack tr ring
uprated diff brace
albins ets shaft
Dodson R35 Syncro set – GR6 bulk ring
Extreme clutch seal A and B
Solenoid C replaced
Bespoke Front propshaft upgrade
MAD extended sump
Oil cooler with switchable fan
Syvecs AWD controller
Suspension
Litchfield suspension
DSC controller
Front track control arm superpro front and rear poly bushes
Whiteline Front and rear anti roll bars with drop links
Brakes
AP radicals 410 mm front discs, 400mm rear discs , carbotech XP20 pads
Trim
Alcantara steering wheel
Carbon bonnet vents
Wheels
TSW Nuremburg alloys 265/305 MPS4S Tyres
Security - fitted
