Some advice needed as im changing my standard turbo’s for 2860-5 on my R34 GTR, I have a standard engine im in the process of acquiring some 720cc Sard injectors but im not to sure what fuel pressure regulator I will need? Im not to clued up on these I know there are two types standard and RJ? What is the difference? Can I get some recommendation on what FPR I should use? I want to keep my standard fuel rail. im looking to gain about 600 hp.
Mods already carried out
Oil cooler kit
Triple core radiator
Apexi cone filter
On coming mods
Surge tank with Bosch 004 pump or upgraded fuel pump?
Upgraded MAF’s or MAP sensor
VI-PEC ECU
Oil catch tank
Future upgrades and mods
Metal head gasket
APR head bolts
Oil restrictor
Head Oil Drain Kit
Cams
120MM intercooler?
Am I heading in the right direction? Some advice would be appreciated. :thumbsup:
Oil cooler kit
Apexi cone filter
On coming mods
VI-PEC ECU
Oil catch tank
Metal head gasket
APR head bolts
Oil restrictor
Head Oil Drain Kit
Cams
120MM intercooler?
