1 - 9 of 9 Posts
This is just a quick note for those still considering using them.
I went there on Saturday with Usher99 (Jon) to have our full 90mm systems fitted from Meister R (wow, more to follow on this, the sound is just incredible) and I've got to say Sly's middle name should be 'attention to detail.'
I don't know how many of you have ever sat there and really looked at the back end of your car, especially while it's up on the ramps, probably not many lol (sad I know), but the OEM exhaust system is slightly out where the tail pipes exit the openings in the lower valance, they hang down by a fraction to the near side which no one would ever know or comment on but in my mind I knew was there, and to ensure this was not unique to my car, we checked it against a few customer cars and Jon's still running the standard set up and got the same result. Annoying!
So after fitting the new system both Jon and I had the same result as the Meister system uses the factory fixing points and brackets, but Sly, in my mind really stepped up without asking, he could of said that's the way it is, but sensing our disappointment after such an agonising wait to get this system, he worked on them both to get the desired result! Everything level and in proportion and the tails now exit dead centre each side with equal spacing all round, perfect!
Sly if you get this 'Thank You mate,' it's refreshing to find a true specialist that treats my car like his own and revels in getting things just right!
(Roll on stage 4) Mark
Popped into Kaizer for the first time today to fix a little niggle - 10 minutes later and a couple of beers tokens, fixed quicker than it took me to grab a burger from the nearby stall and cost nearly the same!
Excellent work and a great chap to boot.
Thanks Sly.
1 - 9 of 9 Posts
