I realise this is pretty trivial......but for those of you with car covers.
What do you do if you arrive home late at night and it's raining.
Do you
a) Leave the car cover off till it stops raining?
b) Just put it on as soon as possible?
c) Dry the car the best you can and put it on? (Not really possible with West of Scotland rain)
Also can anyone explain the issue with putting the car cover on when the car is wet? Does it cause a problem with the cover or does it damage the car?
If you can assume the car is going to be taken out around within 48 hours. Is that too long under the cover from wet.
Cheers in advance.
PS - i've been driving around in Auto with comfort mode (pre-op), but set off at a set off from a set of lights accidentally in manual with a right foot which would see the car change up to 6 rather quickly but didn't,and reminded myself of what a beast the car is!
Do you
Cheers in advance.
