1 - 19 of 19 Posts
Ok Ok I know should be on the Vw Bluemotion forum but what the hell. Whats the best mileage any one seen from a full tank?
bBest i've managed is 195 to date
Had mine for 4.5 years and 43k and honestly couldn't tell you.
My average MPG has been 17.7mpg over the last 1400 miles. So on that basis I should technically be able to get 290 miles out of a full tank (74L capacity?). But that would be driving until there isn't a drop left in the tank!
No idea.....the devil inside me will probably never let me find out either :)
Long motorway run saw 310 miles between full ups.
Usually much closer to 200, as in 190 lol
Last trip to litchfields i got 290+miles from a tank but 240 of them were on the motorway. Usually around 240 normal use.
I've never actually checked my mileage between fill ups i usually glance down at the fuel guage thinking wtf i swear the needle was alot higher a second ago.
I usually average 195 miles to a tank, but saying that it's a bit misleading because the tank holds 16 1/4 gallons (yes I hate litres lol) but tells you you're empty when there are 3 gallons left in the tank, then the reading goes to --- (zero) miles remaining at 2 gallons left, so most of us will probably be using less then 12 gallons between fill ups.
I fill up twice a week costing around £160 quid per week, of which more than a 100 quid of that is tax and value added tax.
I managed 330 once after Iain latest map but I guess around 220-250 ish but you only get 50 litres in when it shows 'empty'.
Very rarely see more than 220 miles unless there has been significant motorway driving. As others have eluded to I would say a reasonable average would be circa 190 miles.
Yup have managed 340 after last ecutek v3 (stg4)map, but then also done 50miles on a full tank too (track).
1 - 19 of 19 Posts
