1 - 20 of 43 Posts
Hi, I have recently had SVM fit the MPSS 275/305 tyres on my Sept 09 GTR.
I think the ride is dramatically better than the Dunlops and Bridgestone runflats.
However, I have a problem! When turning full lock, or anyway near it, the front wheels seem to get stuck, especially at low speeds. Is this normal?
No excessive wear is visible and I can't see any damaged wheel arch or anything.
Is there something I am missing? Should I have installed spacers? I am running stock alloys and suspension.
Any clues would be great along with any tried and tested method of getting a better look under the car without an inspection hole in the floor.
Thanks,
Sounds like a "characteristic" of the drivetrain to me.
Never had any issues with tyre rub.
Discussion Starter · #8 ·
Thanks guys - at full lock and slow speeds (forward and reverse), the front wheels seem to be stuck to the point that the rear wheels start to skip/slip a little. I also notice it on tight corners at slightly higher speeds but the fronts don't stick but seem to 'click/chirp' and understeer a little. I never had this issue prior to the tyre change.
Sounds like the centre diff lock that they altered with software on the 2011 onwards car.
I bet it was there before but you didn't pay as much attention.
It's possible that the tyre contact patch is a different shape due to different inflation and tyre construction and as a result you can feel the binding of the diff in the drivetrain whereas before the tyre may have dragged more easily and prevented the mechanical shunting.
I've noticed the diff lock-up at very low speeds much more recently than in the past. Maybe it's a combination of the surface where I park at work (only seem to notice it there and we've recently moved offices) and me not keep pressures up after the recent drop in temps.
Discussion Starter · #15 ·
SVM will collect my car in the next few days. I have been told that it could well be a 4WD controller issue! (AAARRRRGGGHHHH!!!!) It seems so severe that when I put some revs on to actually move, I fear that something is going to snap (like the diff!). We'll see...
^Shame to hear that, a certain amount of diff locking/shunt is normal. Good luck and keep us posted.
There is never more than 50% of the torque up front so breaking traction would surely always be at the rear not the front.
Even on damp roads I have only ever had the back end chirping a little
Is the 4WD controller a mechanical issue or is it programmable?
Discussion Starter · #18 ·
Thanks to Amar and the team at SVM, my problems are sorted. 4WD coupling changed for a 2nd hand one (AS NISSAN WON'T SELL IT SEPARATELY FROM A GEARBOX!!!!!)
Lesson learnt is to avoid drifting the GTR or simply having fun on ice!
There are quite a few very capable firms around the UK, so why does Nissan not sell the parts separately? I really can't think of a reason why they wouldn't
Hambroski, out of interest what did this cost?
Only ask as mines started doing a very similar thing on full lock at maneovering speeds.
PM me if you'd rather not put it on the open page.
Paul
1 - 20 of 43 Posts
