I've got to pop into my local shopping centre later on this afternoon. Has anyone had any problems with your typical multi-story car park?
I'm sure it will be fine as long as you attack the slopes slightly sideways, but I though it was best to check on here first in case of any horror stories.
I did a quick search but couldn't find anything.
When I left the multi-story at Olympia, the exit had a downward slope, and as I emerged on to the highway the camber of the road was steep enough for the splitter to touch ground. This was in first gear at about 5 mph. This is a situation I am now very wary of.
Got jammed in one in Edinburgh on the run in. The R35 is wide and long, just make sure you are familiar with the layout, I am more worried about a jamming situation than a grounding out. Caught between high kerbs and a "calming" route in will get you in the sh*t
